I need mazda cams
Old 05-11-2007 | 05:14 PM
adams9663's Avatar
Default I need mazda cams
Where can i get mazda cams and pistons to build up my engine. I put NOS on it without headers and explladed the ari intake tube and filter off the car. so i want to build the engine with out NOS. any idea on mags of internet sites
Thanks
Old 05-11-2007 | 08:19 PM
sstlaure's Avatar
Default RE: I need mazda cams
Sounds like you had a Nitrous backfire (had nothing to do with whether you had headers or not.) had everything to do with the Nitrous not being set up properly (you probably went lean.)
A decent Nitrous controller & a proper tune would probably solve your problems
Old 05-13-2007 | 08:50 PM
adams9663's Avatar
it is only a 55 shotof wet NOS. I followed the instructions from ZEX. what do you mean by a tune do you mean a tune up. I have stock spark pulgs and i know i need some different plugs but i dont know where or what kind to get (Any Ideas). it is my first time using NOS so what is a controler is that what is used to retard the timing. have you ever heard of porting a throtalbody and do you know anything aout how its done.
Thanks
Old 05-14-2007 | 08:17 AM
sstlaure's Avatar
When you run Nitrous, you need to run a cooler temp range plug (else you will burn a hole in your piston.) You need to learn how to read spark plugs. After you get on it hard, kill the engine and come toa stop, pull the spark plugs. If you are running the right temp plug and your A/F ratio is correct, there should be a light brown tinge to the electrode area of the plug. I'd recommend doing some research on engine tuning (books are your friend....much more reliable than internet info any day...especially when you can destroy your engine with bad advise.)
ONLY a 55 shot of N20? How much power does your car have stock? If you're talking a 130 hp engine stock, an additional 55 hp is quite a bit. You also have to make sure that the Nitrous doesn't come on too soon in the rpm, or else you'll overproduce torque. Here is the formula that relates HP/Torque: (let's use 700 rpm (idle) and 3,000 rpm as examples)
HP=(Torque*rpm)/5252
55 hp=(x*700)/5252 = 412 ft*lbs
55 hp=(x*3,000)/5252 = 96 ft*lbs
You can see if you kick on your Nitrous at 700 rpm, you're slamming your motor with an additional 412 ft*lbs of torque (break city unless you've got something special under the hood), at 3,000 rpm you are kicking in around 96 ft*lbs, still quite a bit, but a reasonable #. A Nitrous controller will make sure that it kicks on only when you want it too, will regulate/ramp-up how quick the Nitrous comes on, and it will also shut the systemdown should something go bad (like fuel pressure, a catastrophic failure on a Nitrous engine....goes lean on the A/F mixture and meltdown...I recommend a separate fuel pump and fuel pressure gauge for Nitrous applications), they can also work with a retard box to change the timing of your engine(here's an example)
http://store.summitracing.com/partde...p;autoview=sku
Nitrous can be tricky......
Old 06-20-2007 | 03:09 PM
darkmx6's Avatar
that sounds a lot like turbo/supercharging.
supermazda
10-02-2009 10:21 AM
2.0Mazda08
04-23-2008 12:49 AM
b3800v6
01-14-2008 02:35 AM
Level_Up
11-11-2006 05:00 PM
