Idle Problem
#21
So, I took apart the distributor (well almost completely apart) and noticed and O-Ring (or gasket) was broken. I have pics here for you to look at and see if you notice anything besides the o-ring is out of place.
#22
I don't see anything beyond the gasket.
Picture 2 is a bit blurred. Is the tab at 12 o'clock the piece that got the treatment with the hammer ? or is it the one behind at 1 o'clock?
But keep in mind distributors are finicky. Defects are often not obvious to the eye.
#23
Its actually at 5 O'clock. The one in the picture is the one that I didn't see the first time. The one at 1o'clock is the one I took the rubber hammer too. The car was running when I did it, I had hit it a few times. And then I gave it a wack and the car died. I hoping the final wack tore the gasket and its that simple to fix.
So I'm having a hard time finding the gasket. Can I use the old one and put sealant around it?
#24
Bengal:
Sure you can seal it with a silicone. But: the sudden death on the whack leads me to believe that this caused an electrical disruption. Take the connectors off and look for a problem in there.
I once stumbled on a report where a guy took the dremel tool to a MAF sensor. He found that there was a wire inside the casting that developed corrosion. By grinding away the plastic he was able to solder the thing , then he put silicone on it it and it worked just fine. He saved about $400, that's how expensive a replacement would have been.
You are looking at a similar situation, only it's not corrosion or moisture, it is most likely a torn wire possibly hidden inside the plastic casting. Find out how much a new or used distributor would be and then decide if you want to replace it or hack the broken one. I would be a hacker first....what would I have to loose?
#25
Thanks Tan, I'm going to check that out in a minute. I'm going to gave to replace the gasket. I put sealant around it Then as I was placing the gasket on the distributor it broke in a different spot.
About the spark plug test, I'm assuming that if I go through all six and they all create a spark then the distributer is working properly. .
#26
That's right. The coil, distributor and wires would be proven good.
#28
balintkp, did you read all the posts in this thread?
#29
When I go back and see all the threads I've started concerning my car, I wish I would have kept it to just one.
#30
BengalBrad: look what I found:Curbside Classic: 1992 Mazda MX-3 GS – Smallest Production V6 Engine Ever? (Now Updated)
