Intermittent check engine light
Old 01-07-2007 | 02:20 PM
hagerg's Avatar
Default Intermittent check engine light
I have a 95 MX-6 with 4 cylinder engine. The check engine lightcomes on intermittently and engine misfires when light comes on. Car has new wires, plugs, distributor cap, fuel filter, 02 sensor. I just cleaned MAF sensor and throttle body. Anybody have thoughts as to what might be causing this? Check engine light won't stay on and I'm told (if accurate) fault code won't store in memory to tell what the problem is. Any ideas/thoughts would be appreciated.
Old 01-24-2007 | 12:17 AM
joesperformance's Avatar
Default RE: Intermittent check engine light
most codes on the car is stored in memory, u should be able to pull it. if not, check the cps by crank pulley.
Old 02-06-2007 | 02:15 PM
gary730il's Avatar
I had a similar poblem with my mx6's engine check light. At the end of almost doing everything, I found a crack in the rubber air intake hose. Siliconed it and it's gotten much better. CHECK th INTAKE.
pdw001
12-05-2022 02:54 PM
Rockstar
03-13-2015 01:07 PM
KillerTofu
09-13-2014 10:35 AM
brave-heart
04-21-2010 07:44 AM
Michael Goloff
01-04-2010 01:35 PM
Quick Reply: Intermittent check engine light
