Little hottie needs help....please
I have a 93 mx6 2.5 v6 automatic that had trans problems, and ran before trans removal. Replaced the trans , and both axles, but will not start. Check fuel , and fuel pressure both seem good. Checked relays , and both fuse blocks both are good. At this point determined that there was no spark so I replaced ecm, crank position sensor, distibutor, ignition module, and cap. Is there anyone who has a clue to what Im missing, and can give me advice on what to check? ....Thanks Christina
RE: Little hottie needs help....please
I think you might want to focus on the things that were disturbed for the trans replacement. Likely has some thing to do with that. I'd check the ground straps or wires. Have you checked for battery power down at the starter. Maybe also look for pinched wires. Hope this helps.
