None of my door locks work!!!!!
Old 11-18-2007 | 02:36 PM
aen61's Avatar
Default None of my door locks work!!!!!
I have a 1993 Mazda Mx6, I bought the car with one key. It was a copy of the original one. Now the key turns on the car, & opens the glove box, but does not open none of the car doors are trunk. Is it just the doors are key? & what do you think I should do? I thought about geting a new key, I dont know how to go about that. So please help me becouse I plan on doin alot to this car, but I dont wont do keep my doors open all the time.
[IMG]local://upfiles/13033/9EEF5624899D4FB88DAA5A3831D470E0.gif[/IMG]
Old 11-19-2007 | 12:19 AM
fadracing's Avatar
Default RE: None of my door locks work!!!!!
first thing check on the passenger door lock for a key code. You will need to remove the door panel and on the pawl ( the arm on the back of the lock) there should be a 5 digit number . Take this number to a locksmith and they should be able to cut a factory acutate key for the lock
Old 11-19-2007 | 05:31 PM
aen61's Avatar
Were on the back? I took off the door pannel & cut off the plastic. Now i have a clear view of the back of the lock. I see some numbers mixed with letters. But i dont see a single 5 digit set of numbers.
Old 11-19-2007 | 11:43 PM
fadracing's Avatar
The info I gave you was out of my locksmithing manual , it is usually accurate with the info . The numbers mixed with letters may be a code , if the digits are stamped into the lock this is most likley it. You can pm me the code and I will check it for you.
The manual did state that the code is on the pawl wich is the arm on the back of the lock
Old 11-20-2007 | 01:39 PM
aen61's Avatar
Ok well the code does just like this.
1882FC
C8E-G150
Thier is a 2 digit number right on the back of the lock but i dont think thats it. Thier is also one on the back of the handle whitch i dont think it is either becouse its on the handle. This one came on a little black box that had wiresconneting tothe lock. I think this is it.
scotthochgesang
04-12-2011 12:00 AM
FredDunboyne
10-29-2009 08:31 PM
unclebenny
10-22-2007 09:52 PM
alaneh?
08-29-2006 12:26 PM
dlheck
11-21-2005 03:37 PM
