Over Charging the battery
Old 10-25-2008 | 02:09 PM
hamlaw's Avatar
Default Over Charging the battery
Hello, i have a 1992 mx-3. the charge light came on last night. i put a volt meter on it and it is over charging the battery causing it to make the battery acid boil out of the caps. any idea what is wrong. is it my alternator, voltage regulator??? please help
Old 10-26-2008 | 10:00 AM
Mazdatkb's Avatar
Default RE: Over Charging the battery
The voltage regulator is the likely culprit but since it's intregal with the alternator, that unit will have to be replaced. Most shops (even most parts stores) will test the charging system for either no charge or a nominal amount so it's a good idea to do that before you start replacing parts.
Good luck - I hate electrical problems!
Old 10-31-2008 | 02:06 PM
jonnymcfly's Avatar
The alternators can get a bit expensive - over $160 around here. If its just the regulator inside you can get an alternator guy to rebuild it cheaper or pick one up at a junkyard. I found that some kia sephia models 94-95 also has the same alternator assuming you have the 4cyl.
I'll post an ebay link for reference.
http://cgi.ebay.com/ebaymotors/NEW-S...spagenameZWDVW
hotkiwi
12-11-2013 09:00 PM
floater
12-11-2010 10:35 AM
yellowcat
03-14-2009 05:41 PM
