'01 Protege 1.6L engine "bucking"
New to the group and need some help trying to diagnose a problem with my 2001 Protege 1.6L. A few weeks back, the engine was "bucking" (loss of power) at high engine rpm. I removed and cleaned the EGR valve and the problem was solved until now. Now the problem is more severe and any engine rpm speed and causes the engine to stall as well. Any help would be appreciated!
engine bucking
Check the air intake hose carefully for cracks and leaks. I have had 3 "accordian like" intake hoses crack and leak on Proteges causing randon engine "bucking" . If the hose is cracked - just duct tape it together until you can order a new intake hose. A leaking hose causes the mixture to lean out.
DAMN THREAD SORT is Alphabetical
Ticking sound in engine
Have any ideas ?
barbnmatt
08-11-2008 04:52 PM
