02 protege fix keyless entry
Old 01-14-2007 | 03:52 AM
ellykl's Avatar
Default 02 protege fix keyless entry
Hey Everybody!
I purchaseda 2002 Protege LX about a month ago, and the keyless entry died on me already. Checked the battery....checked the power door locks....they are working. Any suggestions?? Could I have disconnected a main wire? (I vacuumed it the other day!)
Thx very much!
Old 01-14-2007 | 02:52 PM
ellykl's Avatar
Default RE: 02 protege fix keyless entry
Okay, never mind.....I found a thread that did the trick......the keyless remote is working again........WOOOOOHOOO!!!!
Old 01-25-2007 | 02:33 AM
blzrd's Avatar
you should post a link to that other thread that helped you out so that others can find what you found.
Old 01-25-2007 | 10:21 AM
ellykl's Avatar
Im relatively new to the forum, so thank you forpointing outwhat I 'should' do.
My keyless entry fob apparently needed to be reprogrammed after my car battery was changed,
1. Remove key from ignition.
2. Open drivers door.
3. Put key in ignition, turn to ON then back to OFF three times.
4. Open and close drivers door three times.
5 Push any single button on the fob TWICE.
98Millenia
04-03-2021 08:23 PM
Cheven8nine
04-23-2012 07:59 PM
Jeff Lange
07-20-2009 09:58 PM
93greenstrat
06-05-2007 12:10 AM
Charvet7
03-18-2007 04:09 AM
