02 Protege5 clutch pedal suddenly stiff
Old 02-11-2013 | 09:22 AM
Reibaldo's Avatar
Default 02 Protege5 clutch pedal suddenly stiff
We have an 02 Protege5 with 230K and over the past couple days I've noticed the clutch pedal feeling stiffer when depressed. The car is still shifting and performing just fine. I also noticed that on only one occasion, two days ago, the brake pedal felt like it had pressure loss which I attributed to icy roads and my imagination.
Noteworthy regarding the clutch pedal:
*Increased stiffness can be felt after driving w/o shifting for several minutes. After the first of several close succession uses, it feels normal until driven for distance again w/o shifting.
*Clutch was replaced and pedal was adjusted about 5-6 months ago. No problems after replacement, and I drive 100 miles/day.
*Fluid level looked full - almost to capacity with no obvious leaks with a quick check. Though from what I can tell, a leak should give the opposite pedal issue.
Thanks for any help anyone can offer. We have owned this car for 4+ years and continue to repair and use it. I'd like to reach 300K and the engine feels strong enough to do it!
OziSpeed6
08-04-2013 11:27 AM
Phil from Loreauville
07-02-2013 06:37 PM
Chiz
09-08-2010 07:25 AM
bobbyt46
03-06-2007 09:10 AM
Itsnotme1988
02-05-2007 12:23 PM
Quick Reply: 02 Protege5 clutch pedal suddenly stiff
