02 protoge5 check engine light
Old 04-24-2008 | 10:08 AM
rascal455ho's Avatar
Default 02 protoge5 check engine light
comes on when low fuel light comes on ,after you add gas to tank.It sometimes may take a key cycle or two to get it to come on. runs fine the whole time
Old 04-24-2008 | 10:15 AM
Default RE: 02 protoge5 check engine light
solid light no blink
Old 04-27-2008 | 08:20 PM
Jabboss1's Avatar
water in gas? causes small misfire
Old 05-05-2008 | 06:34 PM
valadas's Avatar
Would have to read the trouble code to be sure, but if you also notice some erratic or low Idle (looks like misfiring also), I would suspect your EGR valve might need a cleaning or replacement. I cleaned mine a couple weeks ago because I also had some troubles with idle mainly on low fuel or low grade fuel. I was reading a random misfiring trouble code and found a post on this forum about the EGR valve. It seems to be a common problem with the protege5.
That said,my first step would be to etheir buy an OBDII reader (basic models start at around 80$) or get a mechanics to read you the code.
Old 05-07-2008 | 09:32 AM
Jabboss1's Avatar
water in gas indeed I have an 02 protege5 had same issue
Old 05-08-2008 | 02:16 AM
wsoape281's Avatar
do you put the key back in before you finish pumping? if the ignition is turned on when the cap is off, it will trip the CEL for a few key cycles.
Old 05-08-2008 | 09:07 AM
key out.
zzbear
02-01-2015 10:26 AM
chperry
02-06-2013 12:11 PM
Kino
07-06-2012 04:45 PM
20ES
10-29-2011 03:24 PM
rascal455ho
04-28-2008 09:00 PM
Quick Reply: 02 protoge5 check engine light
