1990 protege brakes chatters
RE: 1990 protege brakes chatters
If your brake pedal pulsates and at the same time the steering wheel shakes then your front brake rotors are warped slightly. If they are not below minimum thickness then they should be able to be resurfaced at a machine shop. Would also be a good idea to consider new front brake pads at the same time. Make sure to check that the calipers are not sticking and causing the rotors to overheat.
supercrisp
03-27-2007 11:08 PM
