1996 Protege back brake hub
Old 06-30-2006 | 09:19 PM
Vinnie's Avatar
Default 1996 Protege back brake hub
how do I get the back hub of a 1996 Protege off, Take the two Philipshead screws out then what do I do to get the hub off it is stuck tight? vinnie can email too vmdonelan@msn.com Thanks
Old 07-01-2006 | 12:25 AM
bkey71's Avatar
Default RE: 1996 Protege back brake hub
Here is a detail pic of the rear drum brakes.
You need to remove the phillips screws, most likely with an impact driver if stuck. After the screws are out and if the drum is stuck, you can use a hammer and tap the edges to break it free.
[IMG]local://upfiles/1828/C515A0B645DB46C5940145A2E0C869D3.jpg[/IMG]
Old 07-01-2006 | 01:06 AM
Vinnie's Avatar
Thanks bkey71it is just what I needed vinnie in S.D.
bakari75
04-04-2015 10:44 PM
racsan
05-17-2011 02:36 AM
jaimie08mazda3
06-14-2010 11:47 PM
Vinnie
07-02-2006 09:20 PM
Vinnie
07-01-2006 07:44 PM
Quick Reply: 1996 Protege back brake hub
