1998 Mazda Protege Keyless entry programming
Old 01-27-2007 | 10:29 PM
Charvet7's Avatar
Default 1998 Mazda Protege Keyless entry programming
I got a new remote for my 1998 mazda protege LX. I can't find anywhere instructions to program it. Does anybody know?
Thanks
Old 02-02-2007 | 10:19 PM
babyhuey's Avatar
Default RE: 1998 Mazda Protege Keyless entry programming
I don't think that 98 model offered keyless but here is instructions for 99.
Start with all doors closed and then remove key from ignition.
Open drivers side door.
Insert key back into ignition and then turn key from Lock to Run position three times.
Remove ignition key.
Close and then open drivers door three times.
Power locks will lock and then unlock telling you that you are in programming mode.
Push any button on first transmitter two time.
Doors should again lock and unlock telling you that the programming was accepted.
Repeat last two steps for any additional remotes.
If only have one remote then program it three times.
If only have two remotes then program one of them twice.
When the third remote is programmed then the doors will again lock and unlock automaticaly telling you that programming was successful and is ended.
Old 03-09-2007 | 01:45 PM
bryon89's Avatar
Charvet7...I also own a '98 Protege and am looking into buying replacement remotes.
Have you had any luck locating programming instructions?
Old 03-09-2007 | 07:34 PM
babyhuey's Avatar
Did the above directions not work??
Old 03-13-2007 | 06:36 PM
bryon89's Avatar
Never received anything back from vehicle stating is was in programming mode. (lock and unlock)
Thanks.
Old 03-14-2007 | 01:36 AM
bryon89's Avatar
was just told from someone on ebay selling remotes and programs that the 98 programming is different from the 99 programming.
if anyone comes across the 98 programming, i could use the help
thanks
Old 03-18-2007 | 03:09 AM
mldjlg_02's Avatar
i am having the same problem with programming on my 03. the car does not lock and unlock to tell you that it is in program mode. it does not make sense, but the instructions are correct because they came straight from the service manual. oh well, who knows?
98Millenia
04-03-2021 07:23 PM
kajnjim
09-27-2017 05:44 PM
Cheven8nine
04-23-2012 06:59 PM
jiggaman
07-30-2006 04:24 PM
srozycki
06-19-2006 12:45 PM
Quick Reply: 1998 Mazda Protege Keyless entry programming
