1998 Mazda Protege- Power steering fluid?
Hi,
I have 1998 mazda protege automatic, I saw that the power steering fluid is slightly below the minimum level. I dont have the owners manual for this car.
Can you guys suggest me which fluid should I use to top it off? ATF or power steering fluid?
Thank you!
Thank you!
I've changed all my cars power steering fluid to Mobil 1 synthetic transmission fluid.
With car off use a big syringe and suck out the power steering reservoir. Replace with transmission fluid. Do this about 3 times after driving the car a few miles between each fluid change.
I could not find Dex ii , would this work? It says it is compatible with Dwx ii
Valvoline/1 qt. MaxLife Dex/Merc automatic transmission fluid
hdong1
01-27-2010 07:51 PM
