1998 Mazda Protege stuck in park??
My automatic 98 protege has been parked for 3 months in my backyard. Prior to me parking it there it had no problem shifting at all. Today I went out jumped the battery, started it no problem and let it run for a little then tried to shift into drive...the gear stick wouldnt move i shook it hit it messed with the steering wheel tried using my key and a screwdriver in the shift override and still it wont move form park. I checked the fuses and everything works fine, the brake lights come on and i hear the lock click when i push on the brake. It seems like something is just stopping the stick from moving. Im confused any help would be much appreciated
There is something called a transmission range sensor aka neutral safety switch. It is mounted on the transmission where the cable attaches.
I am thinking that switch is stuck. But check if there is any corrosion on the harness.
Hey sorry for the long reply, but yea its definitely the range switch or at least the bolts attaching it there really rusted and i can see thats whats stopping it from moving. If i just get new bolts would i have to replace the switch? cuz it looks fine. Thanks for your help at least i know what it is now
Sprayed some on and it worked like new im jus glad it was that easy. It rumbles a tiny bit when in drive and reverse but i figure it jus has to work itself out after sitting for so long. Thanks for the help i was really stressing
rgm2744
06-25-2009 01:54 PM
