1999 Mazda Protege 1.8 Headlight Voltage drops?
Hello!
FYI: The plug on the right side had been replaced I don't know when, so I am figuring that maybe the cables were switched. That is why I am verifying the voltage drop.
Low Beam:
I have tried to find the diagram for this model and year online but, I have not been successful.
Sincerely and regards,
LEM
- Vehicle: 1999 Mazda Protege 1.8
- My right headlight is dim when the high beams are on.
- The Low beam work OK.
- I have no issue with the left headlamps.
- This was also happening with the old bulb which I replaced. (I replaced both the right and the left.)
Low Beam:
- For the left side headlight plug, the voltage drop for the top middle connector is 0v, the right connector is 12v and the left connector is .1v
- For the right side headlamp plug, the voltage drop for the top middle connector is 12v, the right connector is .1v and the left connector is 0v
- For the left side headlight plug, the voltage drop for the top middle connector is 0v, the right connector is 12v and the left connector is 0v
- For the right side headlamp plug, the voltage drop for the top middle connector is 12v, the right connector is 0v and the left connector is 0v
LEM
