2003 Mazdaspeed Protege Valve Cover Leak @ 65K
Old 10-30-2007 | 10:05 AM
crackerjakx's Avatar
Default 2003 Mazdaspeed Protege Valve Cover Leak @ 65K
My valve cover gasket has started to allow some oil to seep through. I'm trying to figure out if this is symptomatic of something else or if the gasket is just dead...
For the past 10k miles I've noticed a very slight amount of oil pool on the bottom of the 2 right, front-side, valve cover bolts. It was like that for a while until recently when I did a cruise on the highway with some other local mazda members where I admitedly pushed it a bit. The next day I noticed a bunch of oil that had seeped down from the front of the valve cover, down the head, to the exhaust ports. I didn't lose much oil because the level is about the same. But it has me worried that there was an apparent sudden build in pressure. I've wiped the oil off since and notice more oil seeps out then before, usually noticeable after a day of pushing the car. Should I be worried?
Old 10-30-2007 | 07:58 PM
MazdaES's Avatar
Default RE: 2003 Mazdaspeed Protege Valve Cover Leak @ 65K
Just replace the valve cover gasket and the PCV valve. I have replaced mine on my 1996 twice in 182,000 miles.
Old 11-03-2007 | 09:28 AM
protegedon's Avatar
You absolutely want to be sure to replace the PCV valve as ES suggests, as this can be a contributing factor to valve cover gasket leaks.
[align=left] [/align]
cyberspace
11-18-2016 09:10 AM
kartracer
07-04-2011 06:22 AM
texex2002
12-30-2010 08:30 PM
cugene
05-09-2007 08:49 PM
heliskiier
02-11-2007 01:57 PM
Quick Reply: 2003 Mazdaspeed Protege Valve Cover Leak @ 65K
