2003 Protege5 Exhaust Gas Recirculation Question
Old 03-11-2010 | 03:31 PM
MMA Buffalo's Avatar
Cool 2003 Protege5 Exhaust Gas Recirculation Question
I just removed the stock header to a 2003 Mazda Protege5. I had an issue reconnecting the EGR Valve to the new headers because the stock headers had female threads and the new headers had a male thread. Due to time constraints I plugged blocked off the EGR valve. Right now it runs fine.
Now my question is will any long term effects come from blocking off the EGR valve or should I get it reconnected as soon as possible?
Any help would be great!
Old 03-11-2010 | 04:06 PM
wsoape281's Avatar
it will eventually throw an emissions code without the egr, but it won't affect the performance if you remove it the correct way.
Old 03-12-2010 | 07:06 AM
I was already getting codes for the EGR before (it was probably on the way out) I bypassed it. I'm not in CA so I won't have to pass an emissions test.
After I remove it is there anyway that I can delete the code?
Old 03-12-2010 | 03:12 PM
wsoape281's Avatar
I will have to look it up, but I think that you need to wire a resistor into the harness where the egr plugs in and put a block-off plate on the egr opening.
Cramm557
12-01-2010 03:44 PM
gl1211
02-23-2010 05:31 AM
eric27
09-16-2009 09:43 PM
protege311
11-14-2005 08:08 PM
Quick Reply: 2003 Protege5 Exhaust Gas Recirculation Question
