96 Protege ES ABS malfunction
Old 09-23-2007 | 06:08 PM
kentros's Avatar
Default 96 Protege ES ABS malfunction
Starting car and driving off all is well. Upon first brake application at low speeds under 20 MPH rapid brake
pulsing takes place even without locking up a wheel. Soon after the ABS light goes on and the pulsing stops as well as ABS systemstops working alltogether. Shutting car off and restarting repeats the above process.
Brake system is inotherwise good shape.
What could it Be? Wheel speed sensor? ABS controller?
Can I diagnose this myself ?
Other than dealer any place I can take it to diagnose it ?
like major chainssuch asMavis, Goodyear etc ?
most small shops I deal with around here don't have the
diagnostic capability.
Thanks for any help.
Old 09-24-2007 | 07:15 AM
hixx's Avatar
Default RE: 96 Protege ES ABS malfunction
Pump relays are a common failure and if it were a wheel sensor i would think it would set a light as soon as the car moved. However guessing can get expensive so you will need to get the codes read.
Old 09-25-2007 | 07:26 PM
MazdaES's Avatar
You need to get the code read. Once you do, post it to me here. I have the same model vehicle. {I love blowing BMW's away in the turns} I have a shop manual that we can see what the code menas. Go to a autozone or advance to get the code read, Or buy an Actron code reader. It would be the best $70 you'll spend.
Old 09-25-2007 | 08:17 PM
kentros's Avatar
Thanks for the good advice guys. I'll get the codes read one way or another and will get back to you.
sandman8002
12-07-2006 06:25 AM
JamesB007
08-17-2006 07:06 PM
childrensday
07-14-2006 11:10 PM
toscorpio
07-12-2006 10:46 AM
Jim in CO
03-15-2006 04:46 PM
Quick Reply: 96 Protege ES ABS malfunction
