98 Protege acceleration problems
Old 04-18-2006 | 01:12 AM
txaggie's Avatar
Default 98 Protege acceleration problems
I recently had a new engine put in a 98 Protege (1.5). The car had been sitting for a couple of years. It runs great most of the time. About once a week it will start bucking, surging and loses power. Usually if you stop for a few minutes it is fine. The check engine light has never come on. When my husband scanned it it said that the it needed a catalytic converter. Could this be the problem? I hate to start replacing things unless I know where to start!
Thanks!
Old 04-18-2006 | 02:04 AM
bkey71's Avatar
Default RE: 98 Protege acceleration problems
Has the fuel filter been replaced? It almost sounds like a fuel pressure problem. Another thought is an EGR (Exhaust Gas Recirculation) valve that can be getting stuck open, this will be most noticeable when slowing down after driving at highway speeds.
If you scanned for codes and got the "catalytic converter efficiency" code, this will not cause this problem. If the converter is bad it will happen every time you drive the car, not intermittently.
thenard
04-25-2010 11:18 PM
emily6371
08-20-2009 02:26 AM
RGW123
11-19-2007 05:32 AM
kimari
12-18-2006 11:08 PM
nmcdaniel24
11-29-2006 11:54 PM
