Alarm remote programming
I have a 2003 Protege 5.
Right now I only have one remote control for the alarm/doors. I would like to get a second.
The dealer wants to charge me $45 for the programming and $65 for a second remote.
I can live with the charge for the programming but the cost of the part sounds very high to me.
I looked on e-bay and sure enough I can buy two for $20.
Some questions:
Is it possible for me to program the remotes myself and if so where do I find the procedure?
If I can't program it myself do I need to bring two with me to the dealer for programming since I will lose the one I have now?
If I need to bring two will the dealer want to charge me $45 for each?
Thanks for your help!
Some questions:
RE: Alarm remote programming
Programming the remotes your self is very easy RGKleid.
1. Start with key out of ignition and all doors and liftgate closed
2. Open drivers side door
3. Insert key into the ignition and turn from LOCK to RUN position three times ending in LOCK postion
4. Remove the ignition key
5. Close and open the drivers door three times ending with door open
6. Doors should now automaticaly lock and unlock telling you that you are in program mode. If not then start over at #1 after waiting a few minutes.
7. Push any button on first keyless transmitter two times.
8. Doors should lock and unlock again telling you that keyless ID was recognized and programmed.
9. Repeat step 7 with any remaining keyless remotes.
Arrgh
01-12-2007 01:57 PM
2003, 5, alarm, control, mazda, program, programing, programming, protege, remotes, reprogramming, turn
