bp10 or bp26 for ecu
Old 12-03-2007 | 11:35 PM
mazdasly323's Avatar
Default bp10 or bp26 for ecu
Hi i need help. i got a 1992 mazda 323 with a BP engine (1.8 DOHC) recently put a IHI VJ20 turbo and the air intake manifold from 323gtx . can i run this with my bp 10 ecu or i absolutely need the bp 26 ecu from the gtx
Old 07-27-2022 | 08:09 AM
Maczazda's Avatar
The BP10 ECM is tuned or programed to run timing advance for non turbo. A turbocharged motor needs less ignition timing under boost. If you run too much timing advance on a turbo motor you risk damaging the motor with detonation.
kidoz69
10-23-2017 04:28 PM
hoanggtx
04-27-2009 12:36 AM
bunche
12-11-2008 12:46 PM
mazdasly323
12-03-2007 10:39 PM
No hay panadie pa
01-01-2007 10:47 PM
Quick Reply: bp10 or bp26 for ecu
