car not going into park
Old 06-10-2009 | 04:13 PM
eeuler's Avatar
Default car not going into park
My 03 lx will go into park, but it wont be in park. It just acts as though its in neutral. Has anyone else experienced this, and if so what did you replace. Any help would be great.
Old 06-12-2009 | 11:42 AM
eeuler's Avatar
forgot to mention that the tranny is not slipping or acting funny, it just wont lock the wheels.
Old 06-12-2009 | 11:56 AM
Djslyde's Avatar
My friend had that happen to them once, but they drove several miles with the e-brake on. Don't know if you did that or not.
Old 06-13-2009 | 12:44 PM
eeuler's Avatar
no when it happens i just put the ebrake on for me to park
Old 06-17-2009 | 05:51 PM
eeuler's Avatar
any one had this issue? not sure how to fix it for good.
Old 06-17-2009 | 10:08 PM
oldeng's Avatar
Don't know your car, but Mazdas having a cable linkage between the shift lever and transmission develop an indexing problem where the lever is in the gate, but the switch on the transmission is not in the corresponding position due to progressive wear at the bends between the cable and its surrounding jacket. Fortunately the arrangement can be re-indexed provided the wear is not excessive; the procedure involves a simple adjustment at the transmission switch end.
I hope that's all the problem turns out to be.
This is one of the gadzillion reasons why I won't touch automatics with a barge pole.
Old 06-20-2009 | 12:20 PM
eeuler's Avatar
ill try that out next time it does it. It stopped doing it for now.
Old 06-27-2009 | 02:32 PM
samabhi126's Avatar
I think the problem is in the gear box. Check that.
Old 06-28-2009 | 05:17 PM
eeuler's Avatar
its not doing it now, so gotta wait till it does it to figure it out. Have found that when the problem does work that the o/d switch on the shifter also doesnt work.
darrylt
08-30-2010 08:50 AM
cherakee68
08-02-2010 11:06 AM
BassnTruck
09-28-2008 03:35 PM
thenewbie
04-03-2007 08:58 AM
gurubob
06-12-2005 04:34 AM
Quick Reply: car not going into park
