Cat-back Exhaust
On my V6 3.0 ltr it has 2 pre-cats with O2 sensor before and after each pre-cat. A little further down the exhaust line there is another main cat. I changed all the exhaust piping right after each pre-cat due to the poor design, flow. I also changed the main rear cat to a Magnoflow 1/4" bigger than stock to match the Mazda speed cat back size (and most cat backs) and to match my upgraded crossover true "Y" pipe (dual 2" to 1 2.5"). It flows and sounds great. Easily passed emissions.
Ok thanks. ill have to look into it.. when i got the car from this guy he had cut one of the cats off. and i have to find a new cat eather oem or aftermarket. im new to the smog stuff. never had to deal with the cali laws before. im hating it so much..
Yes, you must have the same amount of cats that car came with. Hopefully he cut the cat off with no O2 sensors around it.
Magnaflow also sells exhaust manifold/pre-cat assemblies which may be cheaper than Mazda and OE equivalent if needed as well as spots for O2 sensors.
Click: Magnaflow has Catalytic Converters with Exhaust Manifolds
