clunking under deceleration
Old 07-02-2009 | 10:06 AM
eeuler's Avatar
Default clunking under deceleration
MY 03 protege recently would not engage into park, but has since fixed itself, but about 2 weeks after this problem there is a new one and there is a clunking or rattling that happens during deceleration. It seems to disappear when i get under 10 mph, but happens progressively worse with speed. The sound doesnt change when im turning hard or anything except when under deceleration. Any one had this problem that could help me out?
Old 07-03-2009 | 11:59 AM
oldeng's Avatar
This could be related to engine mounts. I recall their being problematic. This could also affect the linkage between the shifter and the transmission, explaining the shifting issue too.
Old 07-03-2009 | 02:20 PM
eeuler's Avatar
ill check that out, anything else that i should look at while im checking on the mounts?
Old 07-03-2009 | 02:56 PM
eeuler's Avatar
Mounts look to be in good shape.
Old 07-03-2009 | 08:54 PM
oldeng's Avatar
Yes: your exhaust system suspension and heat shield hardware, although they don't correlate with your shifting difficulty.
Old 07-03-2009 | 10:36 PM
eeuler's Avatar
its not from other parts hitting it, already check all that out. The noise also stays the same when i am coasting and put it into neutral. Could it be the cv shaft?
Old 07-10-2009 | 04:50 AM
eeuler's Avatar
anyone able to help me?
mazpro00
01-01-2015 11:18 AM
aputty
07-31-2010 05:30 AM
Psyleid
01-20-2010 05:41 PM
OdysseyExplorer
06-25-2008 08:21 AM
Bubbles
04-26-2007 08:03 AM
