Disty bad, adding external coil
Old 05-29-2009 | 10:25 PM
mazda bpt's Avatar
Default Disty bad, adding external coil
how do u add an external coil pack to 97 protege 1.5l Z5 i have coil and wire diagram but what wires do i use?
Old 05-31-2009 | 04:35 AM
darkstar4100's Avatar
you want a heavyer wire something like 4-6 gauge the heavyer the wire the better the wire carries the charge i only work with 2 gauge booster cables cause of the way it carries current.
Old 05-31-2009 | 12:51 PM
mazda bpt's Avatar
lol how do i hook it up it has internal coils i have wire diagram but two wires go from disty to ignition module ??
Old 06-03-2009 | 03:57 AM
ohhh i think i know what your talking about now are you installing the coil paks that kinda sit on top of the engines
http://www.aempower.com/ViewProduct.aspx?ProductID=1416
^^ they kinda look like that?
Old 06-04-2009 | 02:16 AM
mazda bpt's Avatar
ah kinda of but not 333 dollars lol mine 13 dollars and i installing ignition control module from a 82 chevy chevelle. wat wires do i tap into from disty? i thing the one that goes to engine fuse that is hot in on and run. i found other diagrams of how to add this but those where for v6. so differnet wireing
littleman626
07-27-2011 03:42 PM
Goatman
05-10-2009 11:14 PM
theboyk
12-14-2007 09:04 AM
PoppyPete
09-03-2007 04:30 PM
chazza55
08-10-2007 04:43 PM
