door open warning light
Old 06-16-2005 | 02:59 PM
barefoot_gal's Avatar
Default door open warning light
Hi,
I have a problem with my 2002 Protege. The warning light indicating that one of my doors is open keeps going on. I know my doors are all closed, and the light usually comes on in the middle of driving, long after I've closed my door, so it can't be that the door is actually open. When I tug on the driver door handle just slightly, the light will go off. It will then come back on again until I tug the door again. It seems the driver door is the culprit, and I got the latch/sensor replaced, but that didn't do the trick. It's driving me nuts! [:@] Has anyone had this problem??
Thanks!
Old 06-16-2005 | 03:22 PM
bdmazda's Avatar
Default RE: door open warning light
sounds like there might be a short in the wiring either inline of the sensor, or in the dash. Check those out and hopefully it will fix the problem.
Old 01-13-2006 | 11:36 PM
derwud's Avatar
i had that same thing happen to me and i could be that one of your door sencors are out/broke thats what mine was check your driver side sencor sence your drive door is used the most islocated on the bottom side on the center piller is black
should stick out halfinch or so if not check others
B-T-S
04-27-2015 01:30 PM
Jfoster89
10-20-2009 03:57 PM
minicar
01-30-2009 09:57 AM
packerfaninva
03-02-2008 03:14 PM
guaranteed
01-04-2007 09:17 PM
Quick Reply: door open warning light
