EGR excessive Flow
Old 12-13-2004 | 08:00 PM
pete2's Avatar
Default EGR excessive Flow
Has anybody else had any occurance with the Engine trouble light coming on indicating Excessive Flow in the EGR valve. I hearing that Mazda is having many call ins on this and tha they are backlogged with requests for replacement parts. I've replaced mine once but now within a week, the light is back on for the same code.
Thanks in advance,
Chris
Old 02-03-2005 | 02:05 PM
MAZDASERVICE's Avatar
Default RE: EGR excessive Flow
THIS IS VERY COMMON-AND YES THE PARTS WERE ON BACK ORDER. IF THE LIGHT IS ON WITH THE SAME CODE-CHECK THE FUEL REGULATOR SPEC...YOU WILL PROLLY FIND THIS IS THE MALFUNCTION
Old 02-15-2005 | 12:05 AM
pete2's Avatar
Someone else suggested removing the throttle body and cleaning out the port that goes to the EGR valve. I used Carb cleaner , reset the light and haven't had any trouble since. Probably could have avoided buying the EGR valve completely. So far, so good, but thanks for the reply.
Later,
Chris
mzdaspd304
08-22-2012 05:38 PM
pony5o
09-11-2010 12:18 PM
rickyp882000
03-26-2009 04:34 PM
Jim in CO
03-15-2006 05:46 PM
stilltryin
05-13-2005 08:44 PM
