Failed Emissions--help?
Old 04-21-2011 | 03:01 AM
mazdaprotege92's Avatar
Default Failed Emissions--help?
Took my '92 Protege to get emissions inspection. Failed b/c hc was high at 196 and CO% was 4.48 but legal limit is 0.61. I just changed my oil so that shouldn't be the problem. Any ideas as to why the CO was so high? Shop wants to charge $100 for diagnostics...
Old 04-21-2011 | 10:58 PM
Dougbug1456's Avatar
You can get high CO from a rich A/F mixture. It could be a mechanical issue(leaky injectors or something else) or it could be as simple as someone was not maintaining it over the years. Is it throwing a code with the MIL on? Where is B/C cat, before or behind the cat? Use pre or post cat to ID the location. Just an FYI!
My suggestion: pay the $100 to a reputable shop giving the idea that you will have them fix it. Get the list of problems and walk. IF YOU ARE NOT SURE HOW TO FIX THE PROBLEMS, let them fix it. You can spend cash on parts and put them in wrong, and then just have to pay the shop to fix it anyway.
EpikYummeh
06-16-2014 07:21 PM
xyza
12-04-2008 11:54 AM
mrclever
11-27-2008 08:31 PM
scifi08
10-21-2008 12:58 AM
brad_rolader
08-08-2008 08:28 AM
Quick Reply: Failed Emissions--help?
