front end shake
Old 02-06-2011 | 10:17 AM
jjfrisk's Avatar
Default front end shake
Just purchased a 2001 protege lx for my 17 year old daughter. Had a shake in the front that felt like a wheel out of balance or maybe a bent wheel. Once on the highway and up to highway speeds it shook real bad. Mechanic said inner cv joint was the problem, but after replacing joints and moving front tires to the rear the problem is still there. Mechanic also says all looks good in the front end. Any ideas?
Thanks,
JJ
Old 02-08-2011 | 10:06 PM
darkstar4100's Avatar
drive beside her on the highway see what side is moving my best guess is bent axel which isn't hard to replace
Old 02-16-2011 | 12:31 PM
djs2571's Avatar
Could be a warped disk brake rotor or dragging brakes causing a warped disk.
Old 02-19-2011 | 06:07 PM
did you ever find out what it was? after thinking about it it could also be a front wheel bearing
Old 02-21-2011 | 07:38 AM
jjfrisk's Avatar
Thanks for the input guys. After the cv joint replacement and the rotation of tires, we tried replaceing tires one by one with the spare. When this was done one tire stood out as causing most of the remaining shake. I replaced two tires to start and when that one came off the rim it had a bunch of "fix a flat" all bunched up on one side throwing it out of balance. When I just spun that tire while on the car I did not notice anything wrong. Now, between the new axles and two new tires it rides good. Not the best, but good enough that I am not afraid to let my daughter drive it around town. Couple of more paychecks and I'll put another two tires on and all should be grand.
Thanks Again & till next time,
JJ
menash2
05-08-2023 01:32 PM
b1_jo
10-24-2008 11:07 AM
kallgrer
03-15-2008 08:05 AM
old soldier
06-15-2007 09:33 AM
spuckett1
05-13-2006 06:12 PM
Quick Reply: front end shake
