intake camshaft seal leak after overhaul
OK SOOOOOOO....i got the thing overhauled new motor right?????? I think not...somethings goofy here tho. i had the guy who did the rebuild replace the seal once. i ran it.. sure as **** same leak. so he tells me he talked to a mazda tech who old him that once you disturb the cam cap its never right so u gotta silicone the thing. so i had him do it again silicone and everything. so i ran it again it leaks. i got pics of what this ****er tried to do...i gotta load them onto the comp. but anywho. i then went ahead and did the ****in seal myself and let me tell u ill load hte pics in a min its ridiculous....but does anyone know of anything...i searced indentifix if anyone is familiar...anyideas let me know. i have pics in the albums section
Sorry for the bad luck. I just replaced mine along with some other stuff on my car and they are holding well. I got them as a part of a top end rebuild gasket set, and the instructions said to apply grease when installing. I used some blue teflon bearing grease on the cam surface and the outer diameter and it has worked well, no issues.
Dumb question - are you installing the ring with the groove facing out or in? Certainly the groove should be facing in. Also I noticed that when I installed mine the inner diameter hangs on the cam and rolls outward as you slide it on. I had to work it back and forth a little in order to let the edge roll back into place
Thanks...but ive been a professional mechanic since 2005 now...and im VERY **** when it comes to gettin **** put back together correctly...i hate comebacks...i learned very early at the ford dealership if u got a comeback...your not makin any money....and nothing has changed since then...i have mitchell on demand, identifix and a boss whos been a mechanic for 30+yrs at my desposal to make sure i get these cars fixed correctly...i just dont know why this car gotta be such a pain in the ***
afinepoint
01-05-2008 03:06 PM
