Low RPM P0506
Old 12-04-2007 | 02:34 AM
fagobg's Avatar
Default Low RPM P0506
Hi Guys
I just got an 03 Mazda Protege LX. I have a small problem
Car idle is low around 600 rpms when the car is on Drive. When the car is in Park the RPMS are normal 800.
The check engine ligth came on after driving the car for 30mins. A friend has a code reader he got a code P0506 Idle control system RPM lower then expected. Can somebody help
Thanks
Old 12-04-2007 | 08:59 PM
MazdaES's Avatar
Default RE: Low RPM P0506
Follow this link
http://protege5.ugly.net/01-02a.PDF
go to page 96. This deals with code you are getting. It could be as simple as a clogged air filter.
That link is for the whole shop manual.
Old 12-04-2007 | 10:48 PM
fagobg's Avatar
Thanks
Old 07-11-2022 | 05:31 AM
maweida's Avatar
Hi all,
My Mazda Tribute, 2006 2.3L L3 motor threw fault code P0506 recently (around 180,000km).
I looked up this forum and it was very helpful.
I checked the air cleaner, and it was very dirty (dated 2016), so ordered a new one.
The hose that is connected to the throttle body was removed, and the throttle body inspected. The vane/casing was quite dirty, I used carby cleaner and rag to remove all the deposits.
During the inspection, I noticed that the flexible pipe, that joins the air cleaner box to the throttle body had a crack. Not having a spare, i used duct tape to seal the crack and see if this helped the fault.
Reassembled car and found:
Idle speed steady at 900 RPM, when A/C turned on, it held 900RPM, before this, when the A/C was turned on the RPM dropped to 700RPM.
The fault has gone away (done around 50km) of driving.
Hope this helps the next person, cheap simple fix (around 30 mins work).
Fastbysuzuki
08-22-2020 08:11 PM
tribute03
04-30-2013 11:21 AM
pharty01
12-06-2011 02:44 PM
MP3me
05-19-2010 08:31 PM
afakasi
07-11-2006 07:42 PM
