Misfire and rough idling
Old 04-14-2012 | 08:50 PM
Pro5Will's Avatar
I replaced my seal kit and everything is running smooth again . Now to start on performance. Any ideas?
Old 04-14-2012 | 09:01 PM
Pro5Will's Avatar
Originally Posted by turbo3000
I check engine light came on a couple of weeks ago and i went to autozone to get it checked out and the code came back as misfire on cylinder 1, so i got the parts for it, which was 4 new coil packs and 4 spark plugs, changed those and seen the the coil pack for cylinder one was burnt up and look like it had gotten water in there some how and the spark plug was all rusted up. After i changed all of that the car ran fine for about a week and then the light came back on, engine is idling very rough and when i give it gas to get up to speed it bogs down bad and vibrates. Now the code is saying cylinder misfire 2. What could be my problem. Please helpppppp
did you also change your plug wires in your change over? Have you checked your new code yet? Maybe a similar problem to mine(vacuum leak). I checked/cleaned my: EGR, IAC, MAF, spark plugs, coil packs, fuel injectors, throttle body, and then searched for a vacuum leak. The spark plug was rusty?? Hmmm. Get the code checked and work from there.
Old 04-17-2012 | 03:24 PM
vinper's Avatar
So replacing seals on fuel injectors did the trick? I have misfire on #3 intermittedly
Old 04-18-2012 | 06:25 PM
Pro5Will's Avatar
Well I fixed the other issues and that was my last one. Try using carb cleaner around your fuel injectors while your car is on, if your hear a change in rpms then I would say that is where your issue is. Good luck
oscarpro
02-11-2015 08:35 AM
STEVE22
11-14-2012 06:16 PM
himi
12-15-2011 03:46 AM
squeaky
01-03-2009 02:14 PM
CardsFan420
11-08-2006 07:25 PM
Quick Reply: Misfire and rough idling
