Need help with 1999 protege 1.6L timing
I had to replace water pump, so pulled off the timing belt in preperation for this. Problem is... I didn't know I was supposed to align all camshaft and crankshaft timing marks prior to taking belt off. While removing the Alternator pulley from the crankshaft, the crankshaft turned a bit while removing the pulley bolts (the camshaft pulleys never turned as far as I could tell). After I replaced water pump, I put the belt on and turned the crankshaft until the camshaft pulleys were in timing alignment, then took belt off, rotated crankshaft until it's marker was in straight up timing alignment, then put belt back on. At this point, all timing marks were in alignment. Next, to check to see if I got everything right, I turned the crank a few times until crank marker was pointing straight up again and checked camshaft alignment marks, everything looked good. I put everything back together, but now the car won't idle, I think it's out of time. No CEL light came on.
How did I screw up the timing? I must have missed a step, maybe I didn't rotate the crankshaft or the camshafts enough turns?? How do I get all pulleys lined up correctly and in sync so I can put the belt back on correctly? Hopefully I don't have to reset the camshaft pulleys.
Thanx for any help!!
Kurt
Kurt
mazda99
08-13-2008 05:18 AM
