needs help power streeing
Old 01-26-2009 | 02:21 PM
saakhan's Avatar
Default needs help power streeing
hey i have protege01 ES having trouble in powerstreeing when i m driving is working fine when i slowdown n making a turn streeing get harder n make noises under the hood i saw some fluid drops i dont know what to do should i change power steering pump or other solution to fix it
Old 01-26-2009 | 05:01 PM
wsoape281's Avatar
Default RE: needs help power streeing
change the pump. it sounds like it is only working at higher rpm's and that is caused by the pump not building pressure. sounds like there is a seal blown inside the pump.
Old 05-02-2011 | 10:45 AM
Jak's Avatar
Jak
I have a similar problem with my 1999. I dont see any leaks and fluid is near the top. My dau took it to jiffy lube and she said they "replaced" the power steering fluid. (??)
Could that have blown a seal in the pump? Do the rebuild kits work?
imurphy
09-04-2010 12:02 PM
Sayheymj
11-05-2009 03:53 AM
perkinsbl
10-04-2007 09:45 AM
Moloch
10-12-2005 11:12 PM
Moloch
10-11-2005 08:58 PM
Quick Reply: needs help power streeing
