New Battery, Rebuilt Alternator, Still a Battery Light
Old 04-07-2023, 08:00 PM
thekiddrokk's Avatar
Originally Posted by oldeng
Be careful: it's worth doing a good inspection/ cleanup of the main chassis ground plate that your battery negative cable is connected to, and the main engine ground on the passenger side engine mount. If either of those aren't well bonded, the alternator will be underloaded, and even with an intermittent ground, the no load alternator voltage will jump high enough to damage it.
Thanks dude I will do that in the morning after replacing a fuel line that blew above the gas tank
Old 12-07-2023, 12:09 PM
VictoriaFergusonn's Avatar
OK, Do as much as you can of the checklist I posted; they are very important.
Old 12-07-2023, 01:13 PM
Where did you post this?
Maybe you meant to say off the information posted by other members on this thread?
Old 08-24-2024, 01:24 PM
Chrys's Avatar
Default 2000 mazda protege
Having same issues took mazda in had
alternator checked dead in the water but this is the second one this year. Daughter randomly bought it used in Feb. We're not sure of its history but I'm guessing not the best salvage title.
Anyway battery same now looking at new issue what is causing her alternator to burn out?
Old 08-24-2024, 02:04 PM
Generally it is better with service question to start your own thread for help. While it may seem that you have the same problem it is seldom the case to many variables. The one I see standing out is the *salvage title.
So maybe start your thread and a few of us can start a positive Q&A specifically for your Mazda.
Make sure when you do that you enter the vehicles information.
Year
exact model
miles
and any and all resent in the last 6 mo. service-related work done including what parts were replaced,
Also the estimated life of the battery?
And where and what brand are you getting alternators from as well new or rebuilt
So about the same information you would fill out at any service shop.
* salvage titles can hold key information about current running gear, drivetrain and chassis problems and concerns that can come up!
ASE
Old 08-31-2024, 06:32 AM
The alternator is controlled by the PCM/ECM.
I have seen PCM's go bad and fry the alternator & battery.
Kbagley
08-17-2021 01:27 PM
Prof
06-06-2017 05:07 PM
Jza
11-14-2008 10:47 PM
kcjaeger
03-12-2007 11:42 PM
protegemaddness
09-28-2006 03:29 PM
Quick Reply: New Battery, Rebuilt Alternator, Still a Battery Light
