new brakes installed
Old 04-05-2015 | 09:01 AM
bakari75's Avatar
Default new brakes installed
ok can somebody tell me where I went wrong
when I press my brake pad down it goes lower than it normally was
the new breaks work kinda but I have to press down a little harder
any reason why it is like that
I already pressed the brake down repeatidly after finishing brakes
Old 04-05-2015 | 09:37 AM
hixx's Avatar
The rear brakes set the pedal height. Clean/adjust your rear brakes. If you can pump the pedal and it comes back up then there is air in the system and will require bleeding or a new master cylinder. On rare occasions a proportioning valve will become stuck. Brake fluid should be replaced every 30k miles.
Old 04-05-2015 | 09:45 AM
did you unseize the slider pins?
Old 04-05-2015 | 01:14 PM
bakari75's Avatar
yes I have unseized them
Old 04-05-2015 | 01:15 PM
bakari75's Avatar
ok I will try bleeding them
Old 04-05-2015 | 05:29 PM
tanprotege's Avatar
Replace all fluid. It works just like bleeding but you keep pumping until the fresh fluid shows at each wheel.
If you have a manual shift replace the brake fluid in the clutch hydraulics as well.
The rear brakes auto adjust when you go reverse and hit the brake.
The e-brake levers inside the drums can get stuck and make the rear brakes drag. I just did our brakes yesterday and I had to put the plate that contains the e-brake lever and auto adjust into a vice, spray it with PB blaster. I had to pry on the e-brake lever (looks like a 2 tine fork) to make it move.
Old 11-09-2019 | 07:51 AM
Claudelavoie's Avatar
Default Get use to it. Beside that, it’s a nice ride
Mazda brakes😩
Rayzcar
07-24-2015 10:56 PM
Traxx
02-04-2012 05:13 AM
Jazzster11
04-05-2006 07:08 PM
customgtp
01-08-2006 11:58 PM
stevecaz
09-27-2005 01:34 PM
