protege wont turn over after vc replacement
Old 11-08-2012 | 02:09 PM
mr.dblanco's Avatar
Default protege wont turn over after vc replacement
hey guys this is my 2nd post on this forum, so i have a 99 auto protege 180 kms, my mechanic told me i had a leaky vc gasket, so i got one yesterday for 40 bucks and replaced it my self using a how to from this site. i put everything back in order, checked the spark plugs, changed the plug wires, put a new pcv valve. When i went to crank it it sparked and it was shaking until it died maybe like 15 seconds. so i looked around and checked out all the wire harness, now it doesnt even wanna turn over, it just trys to start and it soundss awful. any suggestions before i bring out the sledgehammer?
Old 11-08-2012 | 03:42 PM
Kevinkpk's Avatar
Check the firing order.
Old 11-09-2012 | 08:12 AM
tradosaurus's Avatar
You didn't put something back where it belongs. Just check everything real well.
Old 11-09-2012 | 10:24 AM
MazdaTirol's Avatar
I does sound like your firing order is messed up as Kevinkpk said, check to make sure all your wires go to the correct cylinders and try to start again.
Old 11-09-2012 | 11:43 AM
mr.dblanco's Avatar
thanks guys, even though i fixed it shortly after my post, so basically you guys were right i didnt put the wires in a correct firing order. i appreciate, now the only problem is this od light.
Old 11-09-2012 | 06:25 PM
That means your car needs to go to detox.
downontwo
09-13-2012 03:11 AM
mazdadam
04-15-2006 04:49 PM
pfcmooney
11-16-2005 11:38 PM
