Rough Idle
Rough Idle
hae a 1996 protégé wth the 1.5 in it. I have noticed at a stop light the car will start to rough idle all most die. I have recently changed out the fuel filter, changed plugs and wires, along with new cap and rotor. I also checked the breather box and hoses coming from it. I don't see any cracks or tears. Can anyone give me any ideas of what else to check.
READ: https://www.mazdaforum.com/forum/maz...%E9g%E9-31136/
Also possible internal air leak to brake booster, you'll have to pinch off the line while someone else depresses brake to see if change appears.
Videos for Vac leak;
Start the car, get your garden hose and carefully hose down the entire intake manifold very slowly. If you notice a slurping noise and or a dramatic change in idle then you have a air leak, most likely the manifold gasket.
