rust on stock steel wheel behind hubcaps
how do i remove the rust off the stock steel wheel behind my hubcap and repaint them? What products do I use to remove the rust and paint them? Also how do i take the tires off them? Its a 1996 Mazda Protege.
Use a wire brush, Evaporust (Evapo-Rust Rust Remover Home) and a good quality primer and rattle can black. Use flat finish because it hides imperfections better.
Don't remove the tires. Stick index cards between the tire and the rim all the way around to mask the tire before spraying. I saw that in a magazine (project car, or similar).
Study the duplicolor website. Post before and after pictures in the "sights and sounds" forum here.
94 protege's Drilled and slotted rotors, struts and springs, crank pulley and steel braided brake li
dr4g0n3
08-11-2007 08:16 PM
