shifter problem
Old 04-05-2007 | 01:46 AM
wsoape281's Avatar
Default shifter problem
i have a 2002 protege 5 that i got used about a year ago. the original owner had put in a shifter that is barely even a short throw and i have decided that i want to replace it. i have done this kind of work before but i ran into a problem on this one. the shifter that is in it won't come out. i think what happened is that when the original owner put this one in, he didn't lube it up and the bands on it rolled down it and jammed it up. i don't see any damage to any of the other parts that might make it stick, so my question is; does any one have any advice at all that might help me out in this situation? i have tried all that i know and the only thing that i can come up with is to pour some solvents into it and see if that might dissolve the bands enough to pull out.
Old 04-05-2007 | 03:24 PM
dr4g0n3's Avatar
Default RE: shifter problem
anyway you can get a dremel in there and cut it off?
Old 04-05-2007 | 10:21 PM
wsoape281's Avatar
that's kind of the thought that i had earlier. i think also that if i can drill a few holes in it to gut the bearings, i could pull the stick and try to just crush the base and pull it out. the base is just aluminum, so it should just break if i can find a way to hollow it out.
kbyron11
02-09-2012 03:22 AM
abnergzz
01-22-2008 03:01 AM
matchboxcarz
01-12-2006 03:10 PM
bluemx693
09-13-2005 09:15 PM
RS44313
08-08-2005 08:14 PM
Quick Reply: shifter problem
