Valve Clearance Inspection?
Old 11-28-2014 | 12:46 AM
Bstew7890's Avatar
Default Valve Clearance Inspection?
I was perusing the owners manual for the 96 I just bought and in the service intervals page it says to inspect valve clearance every 60 k miles. At first I was astonished that it doesn't have hydraulic lifters but I guess its not unheard of. Has anyone here had to adjust the valves on a 1.5L?
Old 11-28-2014 | 07:24 AM
hixx's Avatar
98 used adjustment shims on top of a solid lifter. I doubt they need adjusting but if they do the procedure is pretty time consuming. Check them with a feeler gauge and write down each one. Remove the cams,measure each adjustment shim and use a thicker shim to get the correct clearance. Reassemble and recheck clearance. A good decarbon like Techron in the gas tank once every 2 months should be all it needs though. The Millenia required a valve adjustment every 60k too but paid 24 hours to do it so nobody every adjusted the valves on them either,they had no issues from lack of a periodic valve adjustment. Keep it decarboned and forget it.
BogusSVO
02-01-2010 04:58 PM
crackerjakx
10-07-2007 06:24 AM
quinto555
01-06-2006 11:57 PM
TONYJETT
06-25-2005 10:41 PM
Quick Reply: Valve Clearance Inspection?
