What kind of rear struts to stop rubbing
Old 06-22-2010 | 04:12 PM
Protege5 SC's Avatar
Default What kind of rear struts to stop rubbing
I bought new rims for my 2002 Protege5, with a 45 offset. Needless to say the 205-55-16 tires I had on the OEM rims were too big, they rubbed inside and out. So I put 205-50-16s on the new rims. Now they only rub on the outside with people in the back seat. Any suggestions as to putting different struts in the back that might alleviate this situation, or any other suggestion. Don't want to buy another set of tires. I would appreciate any help!
Old 07-19-2010 | 10:12 PM
SchecterGuy's Avatar
I have the same problem. I have 205-55-16 Eagle GT's on my PR5. There is maybe an eigth of an inch of space between the tread and the strut. Hopefully someone on here can help.
Old 07-20-2010 | 06:24 PM
Default Found a solution
I went to my Mazda parts dept. and asked them. They referred me to a spring booster clamp that can be used to either lower the spring or inverted to stiffen the spring. I had them installed on the rear, two on each spring, only $14-16 a set. It was the perfect solution. No more rubbing. It does however make the steering feel softer because the rear feels lighter, but still handles well, just have to get used to the new feel.
Old 07-23-2010 | 01:05 AM
Awesome! Will be picking some up ASAP! Thanks PR5 SC
grim_reaper
02-28-2015 02:40 AM
wes5314
06-24-2012 03:50 PM
Karmel83
03-08-2010 01:26 PM
Trev3635
04-14-2009 01:41 PM
CO2Man
03-23-2007 12:21 PM
Quick Reply: What kind of rear struts to stop rubbing
