Why Idle speed can not keep up?
Old 01-09-2006 | 11:48 PM
quinto555's Avatar
Default RE: Why Idle speed can not keep up?
babyhuey bkey71, I really appreciate your help, I'm very happy because I already fix the open circuit of the valve, now I got 12 ohms and it's working as it should be:
Idle speed with all accessories OFF = 750RPM
Idle speed with headlight ON = 750RPM
Idle speed with headlight and high fan ON = 740RPM
Idle speed with headlight, high fan and air conditioner ON = 850RPM
Idle speed when the engine is cool = 1200RPM
The reparing is not so easy, mainly because the winding coil and the brass contact was completely fill with pressure injection black plastic, as ignoring where the wires are located I have to engrave the plastic very slowly in order not to damage the small wires. Also in order to remove the coil from the valve casting has to be first remove the return coil spring of which was epoxy clued to a small spindle, for the removar have to use mototool and micro torch and some dentis tools.
I spend a day for this project, but it is worth every minute.
Old 01-10-2006 | 10:18 PM
bkey71's Avatar
Very good!
Old 01-10-2006 | 10:28 PM
babyhuey's Avatar
You must have the patience of Job quinto555 but it paid off. Nice work.
Old 02-18-2007 | 11:20 AM
baller4tym's Avatar
Hello, I'm having a similar problem with my mazdaspeed protege. Its a 2003 though and has 39k miles.The thing is that I purchased my car with agarrett28 and my car stalls after revinghard or driving a bit fast. The RPMsbottoms outafter releasing the gas and it sometimes shuts off. The idle is steady athalf athousand RPMwhen it turns on and all, so I think it might be something with the idle air control. It has beengarage kept fora few months maybe this is contributing? what I really hope to get answered is whether it is the turbotimer or something pertaining to the turbo so thatI can take to to someone who knows about turbos rather then a mazda dealer. Any help would be great, thank you.
Old 08-20-2007 | 04:35 PM
sonicshockwaves's Avatar
I recently purchased a 2003 mazdaspeed and have had nothing but problems, the car wasprobably run witha nitrous system.nearly stalls out while idling, factory idle speed is 700rpms. already replaced the O2 sensor, along with the MAF sensor, still no help, thinking possibly the idle control valve, any suggestions from anybody??
veralynn
11-18-2014 12:04 PM
oneamous
10-16-2014 01:00 PM
protegedon
03-12-2008 06:09 PM
IMPORTS
04-16-2007 06:11 PM
cchatoney
03-30-2006 11:05 PM
Quick Reply: Why Idle speed can not keep up?
