85 rx7 electric fuel pump
85 rx7 has been in garage for 5 years. New battery. when spraying starter fluid in the carb it will fire up and run until it burns up. does not seem to get any gas to carb. fuel line not clogged. not sure wire connector to fuel pump is hot. what do I do
RE: 85 rx7 electric fuel pump
Would definitely be checking to see that the fuel pump is getting power cowboy 8. Pump is located under car towards rear just inside of left rear wheel area. Should be only 2 wires to it. Blue with white stripe is power in, Black is ground. Should even feel like it is vibrating with key on or cranking. If no power then might check the fuel pump cut relay under the dash just to the inside of the steering column. Four wires to it. 2 are Black with white stripe and are power into the relay with key on. Blue w/ white stipe is out to fuel pump and Black w/ Yellow stipe is coil ground to the ECU. Fuse for entire system is in underdash fuse box (do not have an image but looks like racerboy may in your other thread). Is a 20 amp fuse anyway. Look like it should be 2 down from the start of one of the rows with a 15 on one side and 30 on the other side of the fuel pump fuse.
You don't have a clogged fuel filter do you?
88b26nate
10-30-2012 11:31 AM
Goatman
05-10-2009 10:14 PM
willy3486
03-13-2008 01:35 PM
Variety=Spice
10-11-2007 11:14 PM
