Engine has no compression.....I need Help
Old 10-24-2007 | 02:36 PM
sallenpat's Avatar
Default Engine has no compression.....I need Help
I have a 1988 RX-7 with 149K miles on it. I've had it for two years with no problems. On Sunday, I drove it to play poker. It ran great just like it always does. I parked it and about 3 hours later I went to leave and it would not start. Itried for about 30 mins, but could not get it to start. I had it towed tomy mechanics.Monday morning he tells me that the engine has no compression. I don't undeerstand how that could happen to a car that was sitting in a parking lot. He is not a Mazda mechanic.Does anybody know how that can happen? He tells me that I need a new engine. Is this true. I need some advice. Please help.
Old 10-24-2007 | 02:46 PM
Mazmart Trini's Avatar
Default RE: Engine has no compression.....I need Help
Do you know how he tested the compression? Is he does not know how to work on Rotaries, I am pretty sure that he does not know how to do a compression check properly on them. Install a new set of plugs, but before you do, remove the old ones & crank the car over a few times. Make sure you remove the EGI COMP fuse first. While you are turning over the motor, have someone check to see if a mist is being pushed out the spark plug holes. After doing it about 3 times, install the new plug & reinstall the fuse & see if it helps any. The motor may just be flooded.
Old 10-24-2007 | 03:55 PM
hixx's Avatar
It flooded and washed out the apex seals. Do as mazmart says but squirt some oil in the plug holes to lube the apex seals. I have started hundreds with zero compression, it always comes back.
NRhodehouse
04-19-2015 10:38 AM
SJ2K2004
01-20-2014 06:30 AM
csalinas
06-06-2011 12:08 AM
VanilliwithafewMilli
12-26-2010 03:41 AM
ecousin
12-28-2008 10:40 PM
Quick Reply: Engine has no compression.....I need Help
