gxl problems
Old 02-28-2006 | 01:39 AM
evilgixxer's Avatar
Default gxl problems
my 87 gxl has a flat spot going through the rpm between 3500 and 4000. i havnt been able to figure it out yet and i was wondering if anyone has had this problem or knows how to fix it? im a newbie to the rotary engines but i have a good understanding of them.... just not diagnosing them. any help would be greatly appreciated. thanks
Old 02-28-2006 | 11:55 PM
DropTop88RX7's Avatar
Default RE: gxl problems
Known issue with the 2G RX-7. Its called the 3800 RPM Stumble. It is extremely bad when the car is cold and hasn't had a chance to warm up. One thing is to let it get to operating temp before driving. if you still get the stumble, you can reground your ECU. Basically cutting the original ground and adding 3 thicker ground wires to body also including the original ECU Ground
Old 03-01-2006 | 12:10 AM
evilgixxer's Avatar
Ill have to give that a try while i have it in the garage tomorrow. thanks alot
Old 03-01-2006 | 08:20 PM
not a problem. If you want to really learn about 2G RX-7s, go to http://www.clubfc3s.com
towyld2taim
08-13-2007 11:46 PM
Fox7
08-01-2007 12:17 AM
stoopid_duckie
04-04-2007 04:41 AM
SeattleRX7
11-26-2006 03:37 PM
isl_cruiser
09-25-2006 10:25 PM
Quick Reply: gxl problems
