headlight switch and harness
hey guys i recently had to replace my headlight switch and the wiring harness for my 1988 rx7 gxl bcuz i thought it got wet and toasted it but i replaced everything new and it is still wanting to smoke and produce flames has ne one had this problem and can anyone tell me about what i should do????
RE: headlight switch and harness
You have an unhappy power wire that is somehow making contact with a ground.
Can you isolate where the smoke and flame are comming from and when does it make its appearance (ie, when the key is turned on?, when the battery is connected?, when Neil Diamond is on the radio....)
If you can isolate what wire is getting hot then you can trace where it goes and repair or replace that circuit.
It may be helpful to have a friend duplicate the smoke and fire routine while you look for its source. If the wire is getting hot enough to somke it should be easy enough to find it by touch. You will know when you have found it and as soon as you do have your friend stop duplicating the smoke and fire trick. Then remove the electrical tape or convalute that is covering the wire harness until you find your short to ground.
Good luck and may the force be with you..........................
