oil metering pump lines
I have an 85 Rx-7 GS with a 12a engine that I bought new in May of 1985. I have loved this car since the first day that I owned it. It currently has 66,000 miles on it. It has never seensnow or road saltas I store it every winter. Last fall before I placed it in storage I noticed that there was smoke coming out from under the hood after driving it some distance. When I looked at it I thought that the front housinggasket was leaking a bit. I placed it in storage planing to get it checked out when I took it out of storage this spring. I took it to the Mazda dealer to have the leak checked and was told that in fact one of the oil metering lines was broken! It appears that the 2 o-rings at the oil cooler need to be replaced as well. They quoted me about $700.00 to replace the 2 lines and o-rings, the 3 belts and change the oil. Is this about right? I can not do it myself as I am now disabled. The car still runs great. I just hope that I haven't destroyed the rotor seals. Are there better lines available other then the original plastic lines? If so, where can I obtain them. For the time being I havespliced the oil lines broken halves together with a piece of rubber fuel line but could not get the line in very far. If I have only the one line does this mean that only one of the rotors sealis getting lubricated?
Any help would be appreciated!
RE: oil metering pump lines
WOW henningmd, are they replacing the oil cooler or just resealing!!!!The two small 'o' rings at the base of the cooler are a 1-1.5 hour job. The oil metering lines take about 5 minutes. Think I would be looking at a second opinion quote before you get taken that badly. I would guestimate more at the $200-$300 dollar mark depending upon the going labor rate.
