Slotted Rotors
Slotted Rotors
I think my rotors have kicked the bucket. I always thought my alignment was off cause my car would shake once i got up to 50 or faster, but i soon realized that it only shook when i hit the brakes. They have slowly gotten worse and i think its time for some new ones. Do you guys have any suggestions on where i should look to find some new ones? Should i get slotted or not? Any info and recommendations would be appreciated. Thanks
RE: Slotted Rotors
hey osirisRX7, a good place to find brakes that will work with your car is www.tirerack.com its an awesome website that has both regular and slotted rotors. as for the slotted over nonslotted, you will get a lot more performance out the slotted rotors and they look a lot better on the car, however they do create a lot more brake dust then a nonslotted rotor. you will have to pay more for a slotted rotor because of the performance increase as well as a matched brake pad. tire rack does all of this for you so check out the site.
adamsrotors
06-25-2015 02:07 PM
adamsrotors
06-25-2015 02:06 PM
94 protege's Drilled and slotted rotors, struts and springs, crank pulley and steel braided brake li
dr4g0n3
08-11-2007 09:16 PM
